Configuration Parameters › CONFIG Member Parameters › GATEWAYDPATH
GATEWAYDPATH
Specifies the destination path that CA XCOM Gateway uses when the remote file is a CA XCOM Gateway file. CA XCOM Gateway makes the destination path available as symbolic parameter &GWDPATH for onward delivery.
Range: 0 to 254 characters
Default: None
Note:
- You can specify this parameter in the destination member or in the SYSIN01. Its presence is checked for first in the SYSIN01 and then in the destination member.
- You can use symbolic variables with this parameter in batch SYSIN01. For more information, see Symbolic Parameters in the CA XCOM Data Transport for z/OS User Guide.
