Previous Topic: GETSESSNext Topic: HISTORY_OUT_DD
HISTORY
Specifies the type of history record to be written.
NONE
Specifies that a history record is not written.
ODBC
Specifies that an ODBC history record is written.
VSAM
Specifies that a VSAM history record is written. This option is fault tolerant in that a missing or invalid XCOMHIST data set is ignored. The server starts, but no VSAM history records are written.
VSAMREQ
Specifies that a VSAM history record is written. This option also REQUIRES that a valid XCOMHIST data set be available for use by the server. If an XCOMHIST data set which has the required attributes (as an example, correct RECSIZE and KSDS organization) is not available, the server will not start.
Default: VSAM
