Control files let you map objects in XML document to objects in the repository. You can create a control file in multiple ways. One of them is using the CA Repository Universal XML Exchange Control File Builder. You can also manually create a control file using any XML editor.
The processes, task, and examples discussed here assume that you are using the CA Repository Universal XML Exchange Control File Builder to create a control file.
To create a control file
The CA Repository Universal XML Exchange Control File Builder-CA dialog opens.
Creates a new control file.
Edits an existing control file.
Defines the root element name of the input XML file.
Note: For more information, see Specify the Root Element Name and Id Attr in the Control File Builder help.
Note: For more information, see Specify the Root Element Name and Id Attr in the CA Repository Universal XML Exchange Control File Builder help.
Note: For more information about adding a new link, see Add a New Link Attribute in the CA Repository Universal XML Exchange Control File Builder help.
Note: For more information about mapping input XML file objects to repository entities, see Map XML Objects to Repository Entities in the CA Repository Universal XML Exchange Control File Builder help.
Enables CA Repository Universal XML Exchange Control File Builder to log your activities.
Default: Yes
Specifies the level at which you want the activities logged.
Default: Yes
Values:
Your new control file is created.
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
