Update the Release Number
You must now execute special sets of SQL statements to complete the migration process. These statements are contained in upgrade statement files, which you can run from an option on the Installation Upgrade Customization Menu.
The purpose of these files is as follows:
File
Contents
13
Updates the DBX_SYSTEM table with the correct release and service pack number.
To execute the statement files
  1. At the Installation Upgrade Customization Menu, select option 3 SQL. The Execute Release Statements screen appears.
  2. Enter values into the fields as follows:
  3. Press Enter to generate the JCL.
  4. Check the generated JCL before submission and correct any conflicts with your system environment.
  5. Submit the job and review the results for successful completion codes (0).
  6. Press PF3 twice to return to the Installation Customization Menu.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
