Note: Skip this step if your site does not use CA Repository for z/OS Webstation Option.
If your site uses the CA Repository for z/ OS Webstation Option, perform this step to load the CA Repository for z/OS Webstation Option control data into the CA Repository.
Important! If you already have these products installed, you must review the SHOPCNTL load job prior to running this job. The SHOPCNTL load job overwrites CA supplied search objects. Remove all data about search objects that have been customized.
To run the SHOPCNTL load program to load control data
The Execute Conversion Programs screen appears.
Specify SHOPCNTL.
Specify E.
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
