The next step of the installation process consists of rebuilding the repository ALL DBEXCEL privilege.
-------------------------- CA Repository for z/OS -------------------------- ----------------------------- Grant DB2 Privileges ------------------------ COMMAND ===> Grant Privileges to... User TSO ID ===> USER1 ===> ===> ===> ===> Set SQLID to? ===> ARZUSER Authorize ALL DBEXCEL? ===> Y (Y-yes,N-no) GRANT DB2 Privilege? ===> SELECT (INSERT,UPDATE,DELETE,SELECT,ALL) with GRANT OPTION? ===> N (Y-yes,N-no) Edit or Submit? ===> E (E-edit,S-submit) Save Output? ===> N (Y-yes,N-no) Output Data Set ===> Enter ENTER command to continue or END command to EXIT.
Type your TSO ID in the first field. Leave the remaining ID fields blank.
The SQLID you want to use when granting user privileges. If you enter a value in this field, a SET CURRENT SQLID statement is added to the beginning of the job.
Specify Y.
Leave blank.
Specify N.
Specify E.
Specify Y to save the generated JCL in the data set specified in Output Data Set.
Specify N to discard the JCL after running the job.
The fully qualified name (without quotation marks) of the partitioned data set you want to use to save the JCL that this step generates. Ensure that you change the names if you do not want to overwrite any previously saved JCL.
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
