Load Component Data Tables
You must execute this step if your site has or is adding support for any of the
following:
This step loads the data used by various repository components. If your site does not use any of these repository products, you can skip these tasks and proceed to the next step.
To load the data tables
  1. At the Installation Customization Menu, select option 15 Component Load.
    The Load Component Data screen appears.
    ---------------------------- CA Repository for z/OS --------------- ----------------------------- Load Component Data ----------------- COMMAND ===> Load Data For... ERwin? ===> N Webstation Option? ===> N Edit or Submit? ===> E (E-edit,S-submit) Save Output? ===> N (Y-yes,N-no) Output Data Set ===> Batch Job Card: ===> //ARZOS011 JOB (116200000),'INSTALL JOB ',CLASS=M, ===> // MSGLEVEL=(1,1),MSGCLASS=X,TIME=1440, ===> // REGION=0M ===> /*JOBPARM SYSAFF=CA31
  2. Enter values into the fields as follows:
    Specify Y to load mapping data for that tool into the CA Repository control tables.
    Specify N if you are not installing support for that tool.
    Specify E.
    Specify Y to save the generated JCL in the data set specified in Output Data Set.
    Specify N to discard the JCL after running the job.
    The fully qualified name (without quotation marks) of the partitioned data set you want to use to save the JCL that this step generates.
    Ensure that you change the names if you do not want to overwrite any previously saved JCL.
    The batch Job statement you want included with the JCL stream generated by this procedure
    If you leave any of these fields blank, it defaults to a JCL comment (//*).
  3. Press Enter.
  4. Check the generated JCL before submission and correct any conflicts with your system environment.
  5. Submit the job and check the output for errors. A return code of 5 or less is expected.
  6. Press PF3 twice to return to the Installation Customization Menu.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
