Bind All Plans and Packages
This step binds all the CA Repository utility packages. Binding the packages at this stage is essential for later steps of the installation process.
To bind the utility packages
  1. At the Installation Customization Menu, select option 9 Plans. The DB2 Plans and Packages screen appears.
    ---------------------- CA Repository for z/OS ------------------------ ---------------------------- DB2 Plans and Packages -------------------------- COMMAND ===> Prepare Packages … Utility, All, or Foreign packages? ===> A (U, A, F) Set SQLID to? ===> USER01 BIND Plans? ===> Y (Y-yes,N-no) Auth ID of Plan? ===> Grant to PUBLIC? ===> N (Y-yes,N-no) Foreign Cat SSIDs? ===> ===> ===> Foreign Cat DB2VER? ===> ===> ===> Edit or Submit? ===> E (E-edit,S-submit) Save Output? ===> N (Y-yes,N-no) Output Data Set ===> Enter ENTER command to continue or END command to EXIT.
  2. Enter values into the fields as follows:
  3. Press Enter to generate the JCL.
  4. Check the generated JCL before submission and correct any conflicts with your system environment.
  5. Submit the job and check the output for errors. Things to look for include:
    Note: You can ignore any +562 SQL codes on the GRANT step. This message indicates that the authority you are attempting to assign has already been given.
Package
Response
PRMPR32
Can be ignored if you are using InfoRefiner and the InfoRefiner tables are not in this DB2 subsystem.
DBXLQMF
Can be ignored if QMF is not installed in the DB2 subsystem
Any other package name
Look for the program name in the repository ISPPLIB member PROGDEF. Find the program name starting in column 1. Column 54 of this member contains the FMID. A blank FMID is the same as CP$70. If you did not select the FMID at SMPE installation time you can ignore the errors.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
