At this point you must update the CA Repository for z/OS DB2 table catalog statistics using the DB2 utility, RUNSTATS. The statistics are used to calculate the size of the unload data sets in the next step Bind All Plans and Packages.
To run the RUNSTATS against the tables for all products you selected for installation in Define Installation Defaults
--------- Run DB2 Utilities ------------------------- COMMAND ===> Execute Utilities Utility? ===> RUNSTAT (RUNSTAT,REORG,ALTER) Edit or Submit? ===> E (E-edit,S-submit) Save Output? ===> N (Y-yes,N-no) Output Data Set ===> Enter ENTER command to continue or END command to EXIT
Specify RUNSTAT.
Specify E.
Specify Y to save the generated JCL in the data set specified in Output Data Set.
Specify N to discard the JCL after running the job.
The fully qualified name (without quotation marks) of the partitioned data set you want to use to save the JCL that this step generates. Ensure that you change the names if you do not want to overwrite any previously saved JCL.
Note: The DB2 Utilities screen performs the RUNSTATS and REORG utilities only on tables created in the databases listed in your DB2 Defaults (see Define DB2 Defaults). If extended entity tables are in different databases, you have to create the utility JCL by hand.
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
