Execute SQL Statements
You must now execute special sets of SQL statements to modify some of the DB2 objects used by the CA Repository. These statements are contained in upgrade statement files, which you can run from an option on the Installation Upgrade Customization Menu.
The purpose of these files is as follows:
File
Contains Statements That ...
1
Create view, primary key and foreign key for the DBX_WORKSTATION_D table.
Create views for Webstation Option
2
Create additional indexes for elements and workstation table
Create tablespace and table 'TEMP_SUBTYPES'
4
Create History tables and Triggers for the text, cross reference and workstation cross reference tables.
NOTE: If you have created History tables in r7 you can skip executing the DDL in this file.
10
Add APPREQ information to DBX SYSTEM table.
19
Add new datatype NVARCHAR,NCHAR to DBX DDL ELEMENTS table.
The DDL will set the datatype to NVARCHAR and NCHAR where it is currently USER and the picture clause is nvarchar, nchar, NVARCHAR or NCHAR.
To execute the statement files
  1. At the Installation Upgrade Customization Menu, select option 3 SQL.
    The Execute Release Statements screen appears.
  2. Enter values into the fields as follows:
  3. Press Enter to generate the JCL.
  4. Check the generated JCL before submission and correct any conflicts with your system environment.
  5. Submit the job and review the results for successful completion codes (0). Errors you may encounter are listed in the following table.
Error
Occurs when
And can be resolved by
+100
No rows are found.
Ignore this error.
+162
A tablespace is in check pending status.
Removing the check pending status from the tablespace. For information, see the DB2 documentation or contact your DB2 DBA.
+541
Constraint is a duplicate.
Ignore this error if the referential constraint WKSN$ID exists.
+562
A grant is ignored because the grantee already has the requested privilege.
Ignore this error.
-454
The create function already exists.
Ignore this error.
‑601
The object already exists.
Ignore this error.
-624
Table already contains constraint.
Ignore this error if the DBX_WORKSTATION_D table already contains a primary key.
Investigate any other errors with CA Technical Support.
  1. Press PF3 once to return to the CA Repository for z/OS Execute Release Statements panel.
  2. Repeat Steps 2 through 5. When setting up the parameters for Copy Members to Custom Libraries, change the value of the Release Statement File from:
    1. 1 to 2
    2. 2 to 4
    3. 4 to 10
    4. 10 to 19
  3. Press PF3 twice to return to the Installation Customization Menu.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
