Load the New Data
This step loads the upgrade's new and modified code tables, commands, dialogs, entity types, messages, and maps.
Note: This step creates several temporary control tables that it uses to determine what it should delete from your control tables. The intent is to delete only rows that contain CA‑supplied data and then reload the new data. Any additions or changes you have made to the control data are retained when the CA control data is reloaded. Contact CA Technical Support if you have any questions about this process.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
