In this step, do the following:
Once the plans and packages are bound, CA Repository GRANTs access to PUBLIC for the CA Repository plan. Granting to PUBLIC saves time required to enroll new users and saves DB2 connection time when checking for plan access privileges.
To bind the utility plans and packages
-------------------------- CA Repository for z/OS ---------------------------- ---------------------------- DB2 Plans and Packages -------------------------- COMMAND ===> Prepare Packages ... Utility, All, or Foreign packages? ===> U (U, A, F) Set SQLID to? ===> ARZUSER BIND Plans? ===> Y (Y-yes,N-no) Auth ID of Plan? ===> Grant to PUBLIC? ===> N (Y-yes,N-no) Foreign Cat SSIDs? ===> ===> ===> Foreign Cat DB2VER? ===> ===> ===> Edit or Submit? ===> E (E-edit,S-submit) Save Output? ===> N (Y-yes,N-no) Output Data Set ===> Enter ENTER command to continue or END command to EXIT.
Specify U to bind only the Utility packages.
The SQLID you want to use when creating the plans.
If you enter a value in this field, a SET CURRENT SQLID statement is added to the beginning of the job.
Specify Y to bind the plans and packages.
Specifies the AUTHID to use for the OWNER parameter of the bind.
Specify Y to grant access to the generated plans to the special DB2 ID, PUBLIC.
PUBLIC access to a plan does not grant individual users access to the Repository data. We recommend that this switch be set to Y during the initial repository installation.
Leave blank.
Leave blank.
This field should be blank during the initial installation.
Specify E.
Specify Y to save the generated JCL in the data set specified in Output Data Set.
Specify N to discard the JCL after running the job.
The fully qualified name (without quotation marks) of the partitioned data set you want to use to save the JCL that this step generates.
Ensure that you change the names if you do not want to overwrite any previously saved JCL.
Unsuccessful BINDs that you can ignore are listed in the following table. If any unsuccessful BINDs occur that are not listed in the table, report them to CA Technical Support.
Package |
Action |
PRMPR32 |
Can be ignored if you are using CA InfoRefiner and the CA InfoRefiner tables are not in this DB2 subsystem. |
DBXLQMF |
Can be ignored if the QMF object tables were not installed into the DB2 subsystem. |
If the job ends with any return code other than 0, contact CA Technical Support.
Note: The plan and collection names that this step generates are written to the DBXPARM member in the CAI.SHLQ.CUST.ISPPLIB data set for use after the installation.
| Copyright © 2009 CA. All rights reserved. | Email CA about this topic |
