Execute Preload SQL Statements
You must now execute the SQL statement prior to loading new control data. This statement is contained in the upgrade statement file, which you can run from an option on the Installation Upgrade Customization Menu.
The purpose of the file is as follows:
File
Contains Statements That ...
6
Update OO Model objects
Update Entity 27521 RETURNS. Change Association to Relationship. Set Target object to 27509
Update Entity 27504 CL IN FL. Change Association To Relationship. Set Source object to 27517
Update Entity 27507 CL MB FU. Change Association To Relationship. Set Source object to 27517
11
Install WSO DB2 Objects.
Note: New WSO tables in r7.2 have been added
17
Add items new to r7.2
Add APPROVAL REQUIRED flag to ENT TYPE DESC Table
Add approval table
Add new stored procedures
To execute the statement files
  1. At the Installation Upgrade Customization Menu, select option 3 SQL.
    The Execute Release Statements screen appears.
  2. Enter field values as follows:
  3. Press Enter to generate the JCL.
  4. Check the generated JCL before submission and correct any conflicts with your system environment.
  5. Submit the job and review the results for successful completion codes (0). Errors you may encounter are as follows.
Error
Occurs when
And can be resolved by
+562
A grant is ignored because the grantee already has the requested privilege.
Ignore this error.
‑601
The object already exists.
Ignore this error.
Investigate any other errors with CA Technical Support.
  1. Press PF3 twice to return to the Installation Customization Menu.
  2. Repeat Steps 2 through 5. When setting up the parameters for Step 2,
    change the value of the Release Statement File from:
    1. 6 to 11
    2. 11 to 17
  3. Press PF3 twice to return to the Installation Customization Menu.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
