Migration Information › Specify the Models to Install
To specify which CA Repository for z/OS models you are installing
- If you currently have data loaded into the repository that is no longer supported with this product release, and you want to retain the ability to view the non-supported data, you must complete the instructions contained in the Non-Supported Models checklist in the appendix "Checklists."
Important! Failure to complete this task prior to execution of this step results in loss of non-supported data.
- At the Installation Customization Menu, select option 4 Products. The Model/Control data Selection screen appears.
The models that were previously selected remain.
- If you want to select this model change the value to Y then enter the END command or press PF3 to return to the Installation Customization menu.
Note: If you are not certain which models to install, see the Product/Model Checklist in the appendix "Checklists," or refer to your license agreement.
- When you are finished, enter the END command or press PF3 to return to the Installation Customization Menu. If you need to make changes, you can reselect this screen and enter your changes during any step of the installation process.
