Migration Information › Define Installation Defaults
To carry over the installation defaults to r7.2, you may refer to the DBXPARM in the CAI.SHLQ.CUST.ISPPLIB from your r7 installation. You will need to update the DBXPARM in CAI.SHLQ.CUST.ISPPLIB for your r7.2 libraries before verifying the defaults. For details about installation defaults, see Define Installation Defaults in the chapter "Configuring Your Product."
To verify Installation Defaults
- At the Installation Customization Menu, select option 1 Defaults. The Default Values screen appears.
- Default values from the DBXPARM member display.
- When you finish, enter END or press PF3 to redisplay the Installation Customization Menu.
To verify The DB2 Defaults
- At the Installation Customization Menu, select option 2 DB2 Defaults. The DB2 Defaults screen appears.
- The DB2 values appear.
- When you are done, enter END or press PF3 to redisplay the Installation Customization Menu.
To verify the ISPF default libraries
- At the Installation Customization Menu, select option 3 ISPF Defaults. The ISPF Default Libraries screen appears.
- The ISPF Default libraries display.
- When you are finished, enter END or press PF3 to redisplay the Installation Customization Menu. If you need to make changes later, you can reselect the screen and enter them during any installation step.
To verify the STEPLB member
