Access the Installation Customization Menu
After you unload the ISPF data sets and customize the ARZOS CLIST, you can access the CA Repository for z/OS Installation Customization Menu that lists options for installing, customizing, and upgrading the repository and its add‑on tools. Each of the menu options represents a step in the installation process.
To display the Installation Customization Menu screen
  1. Enter the following at the ISPF command line:
    TSO  ARZOS I
    The Installation Customization Menu appears.
  2. Continue with installation.
-------------------------- CA Repository for z/OS ---------------------------- ---------------------- Installation Customization Menu ----------------------- COMMAND ===> More: 1 Defaults - Define Installation Defaults 2 DB2 Defaults - Define DB2 Install Options 3 ISPF Defaults - Define ISPF Install Options 4 Products - Set Product Switches 5 Batch - Set-up Batch Parameters 6 Steplib - Setup Steplib member 7 Create - Create DB2 Objects for Control Information 8 Load - Load DB2 Control Tables 9 Plans - Prepare Repository Plans and Packages 10 Create Data - Create DB2 Objects for Data Tables 11 Security - Grant User Privileges 12 DB2 Utilities - RUNSTAT, REORG, ALTER Repository Tablespaces 13 Upgrade Menu - Install Upgrades 14 Name Gen - Define Name Gen Parameters 15 Component Load - Load Data for Components 16 Path Load - Load Sample Path Definitions 17 Domain Load - Load Sample Domain Definitions 18 Global Cmds - Load Sample Global Commands Enter END command to EXIT.
Copyright © 2009 CA. All rights reserved. Email CA about this topic
