Use the steps in this topic to install the following required components on a standalone server or NFA console server that is running Windows Server 2003:
The Add or Remove Programs window opens.
The Windows Components Wizard window opens.
The Application Server dialog opens and displays a list of optional Application Server components.
The Internet Information Services (IIS) dialog opens and displays a list of optional IIS subcomponents.
The World Wide Web Service dialog opens and shows a list of subcomponents.
You return to the Internet Information Services (IIS) dialog.
You return to the Application Server dialog.
You return to the Windows Component Wizard.
The system locates the files for the update. If any files are missing, a message opens. In this case, insert the Windows 2003 Server Edition CD-ROM or specify the path to the missing files.
A message notifies you when the preparations are complete.
The Windows Components wizard closes. The Windows configuration changes are complete.
| Copyright © 2013 CA. All rights reserved. |
