ToS Summary (Table)
The ToS Summary (Table) views show rate, volume, or utilization for the top ToS values of the traffic on a particular interface. You can use this information to compare traffic for each of the top ToS values.
The example graphic is a ToS Summary (Table) view that shows the rate for each listed ToS value. You can configure the view to display rate, utilization, or volume information.
The ToS Summary Table views show the rate, utilization, or volume of the top ToS values on the interface.
The view contains an interface identification string and a table. The table contains a row for each ToS with the Type of Service identifier (EF/AF, DSCP, and ToS values) and the following rate, volume, or utilization information:
By default, views and reports show the most recent 24 hours of data.
To see a ToS Summary (Table) view in CA Performance Center, add it to a custom dashboard.
Available Actions for This View
You can perform several actions in this view, including the following actions:
Find ToS Summary Tables in the NFA Console
You can display ToS summary tables in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
