The NFA console or standalone server must be registered as a data source with a supported version of CA Performance Center or CA NetQoS Performance Center:
The registration task depends on your upgrade type:
The Manage Data Sources page displays the current list of registered data sources.
The Add Data Source dialog opens.
Note: All CA products that can be registered as CA Performance Center data sources are shown in the Source Type list. The list is not filtered to show installed products.
No data from this data source is reported until you edit the data source to select the Enabled status. Views from this data source display a message stating, "No data to display".
For more information, see the CA Single Sign-On User Guide.
Note: SSL can be used for communications between CA Performance Center and the data source products. For more information, see the CA Single Sign-On User Guide.
By default, the data source type and the hostname are combined to create the display name. You can supply another name here. For example, instead of NetworkFlowAnalysis@xxx.x.x.xx, you can name the data source NetworkFlowAnalysis_NewYork.
The Data Source List shows the CA Network Flow Analysis deployment that you registered.
Note: If you upgrade from CA NetQoS ReporterAnalyzer 9.0.1, you also will change to a new SSO version. Update any previous SSO LDAP configuration and check other SSO customizations. Options from the previous SSO version may not match the current options or may not comprise a full set of the current options. For information about configuring SSO, see the Single Sign-On User Guide.
If an HTTP Request Error opens when you attempt to display the Group tab, clear your browser cache. The error may indicate that you browser is attempting to reload an outdated page.
| Copyright © 2013 CA. All rights reserved. |
