Download the Installation/Upgrade Files
Copy the installation/upgrade files to the installation server so you are certain to have access to the files. Obtain the CA Network Flow Analysis installation/upgrade files from CA Technical Support, then perform one of the following tasks:
- Burn the ISO files to a CD-ROM or DVD.
- Extract the contents of the ISO files by using an ISO image software application. Many ISO image applications are free.
Extract the appropriate files to the installation servers:
- Standalone servers:
- NFHarvesterSetup9.1.3.exe
- RAConsoleSetup9.1.3.exe
- consoletool-exe.jar
- Windows Harvester servers in distributed architecture deployments:
- Linux Harvester servers in distributed architecture deployments:
- NFHarvesterSetup9.1.3.bin
- DSA servers in three-tier distributed architecture deployments:
You can install or upgrade the software locally or remotely.
