Windows Operating System Requirements
CA Network Flow Analysis 9.1.3 supports upgrades of software versions installed on servers with the operating systems noted in the following table:
Software Version
Operating System
From RA 9.0.161 to NFA 9.1.3
Windows Server 2008 R2 Standard edition or Windows Server 2003 Standard edition (all components)
From RA 9.1.00 to NFA 9.1.3
Windows Server 2008 R2 Standard edition (all components)
Red Hat Enterprise Linux 5.5 or 5.6 (Harvester)
From NFA 9.1.1 to NFA 9.1.3
From NFA 9.1.2 to NFA 9.1.3
CA Network Flow Analysis 9.1.3 supports Windows Server 2008 R2 Standard edition and Windows Server 2003 Standard edition for all components. For help upgrading your Windows operating system in preparation for the CA Network Flow Analysis upgrade, contact CA Technical Support.
If you add components on new servers to your upgraded configuration, you can install the software on servers with the following operating systems:
The servers must meet the following requirements:
Notes:
If you have either of the following special situations, ask for help from your CA Support Availability Manager:
