Disable Unneeded Services on Windows Server 2003
If you want to disable unneeded services on Windows Server 2003 systems in your deployment, use the steps and list in this topic.
  1. Log in as a user who is a member of the Administrators group.
  2. Open the Services window: Select Start, Administrative Tools, Services.
    The Services window opens.
  3. Right-click the following services and select Manual or Disabled.
    Do not select Stop or the services will restart whenever the server is rebooted.
Windows 2003 Services That You Can Disable
  • Application Layer Gateway Service
  • Application Management
  • Distributed Link Tracking Client
  • Distributed Transaction Coordinator
  • DNS Client
  • Function Discovery Resource Publication
  • Human Interface Device Access
  • Netlogon
  • Network Location Awareness
  • Print Spooler
  • Remote Access Auto Connection Manager
  • Remote Access Connection Manager
  • Remote Registry
  • Resultant Set of Policy Provider
  • Secondary Logon
  • Smart Card
  • Special Administration Console Helper
  • Telephony
  • Volume Shadow Copy
  • Windows Audio
  • Windows Color System
  • WinHTTP Web Proxy Auto-Discovery Service
  • WMI Performance Adapter
