Use the steps in this topic to configure the SNMP service as required on all Windows Server 2003 servers in your CA Network Flow Analysis deployment.
The Add or Remove Programs window opens.
The Windows Components Wizard window opens.
The Management and Monitoring Tools dialog opens.
The Management and Monitoring Tools dialog closes and you return to the Windows Components Wizard screen. SNMP is set to be added.
The system locates the files for the update. If any files are missing, a message opens. In this case, insert the Windows 2003 Server Edition CD-ROM or specify the path to the missing files.
A message notifies you when the preparations are complete.
The Windows Components wizard closes. The selected components are added to your Windows configuration.
| Copyright © 2013 CA. All rights reserved. |
