Configure SNMP on Windows Server 2008 R2
Use the steps in this topic to configure the SNMP service as required on all Windows Server 2008 R2 servers in your CA Network Flow Analysis deployment.
  1. Log in to the server as a user who is a member of the Administrators group.
  2. Select Start, Administrative Tools, Server Manager.
    The Server Manager window opens.
  3. Click Features in the left pane.
    The Server Manager window displays a list of the installed features.
  4. Click Add Features in the right pane.
    The Add Features wizard opens and shows the list of selected and available features.
  5. Select the SNMP Services check box in the list.
    A confirmation message appears.
  6. Click Add Required Features.
    The Confirm Installation Services page identifies the features to be installed. The page also displays important messages about the installation or upgrade.
  7. Click Install.
    The Installation Progress page opens. When the installation or upgrade is complete, the Installation Results page opens, identifies the new features, and indicates whether you will need to restart the server.
  8. Click Close.
    A message asks whether you want to restart the server now.
  9. Click Yes.
    After the server restarts, the Features view in the Server Manager window shows the newly installed feature.
