Adobe Flash Player is used to view reports and the Administration System Status page. We recommend that you install the latest version of Flash Player from http://get.adobe.com/flashplayer/.
Adobe Acrobat Reader is required on any system that you use to view the product documentation in PDF format. If you do not have a recent version of the Acrobat Reader, install the latest version from http://get.adobe.com/reader/.
Required/Optional |
Operating System |
Servers to Configure |
Recommended |
Windows Server 2003. Windows Server 2008 R2 |
Standalone, Console |
| Copyright © 2013 CA. All rights reserved. |
