Supported Web Browsers
Access to the NFA console is supported for Microsoft Internet Explorer version 7 or 8. Version 8 is recommended. Other browsers or browser versions may work with CA Network Flow Analysis, but have not been tested. Microsoft Internet Explorer version 10 is not supported.
Required/Optional
Operating System
Servers to Configure
Recommended
Windows Server 2003. Windows Server 2008 R2
NFA console server
Standalone server
Required
Servers that are used to log into the NFA console
Note: To set up CA Network Flow Analysis and work with data in the CA Performance Center Console, use Internet Explorer 8 with compatibility mode turned off. To work in CA Network Flow Analysis directly, you can use Internet Explorer 7 or 8 with compatibility mode turned on or off.
If Internet Explorer 8 Developer Tools are installed, you can turn off compatibility mode for the current browser session:
  1. Press F12 on your keyboard.
  2. Click the Browser Mode item on the main menu.
  3. Select Internet Explorer 8.
If your enterprise has a policy that requires the Internet Explorer 8 browser to operate in compatibility mode, you may want to use Internet Explorer 7.
