Ports to Open for a Three-Tier Distributed Deployment
Data flows to Harvesters, then to the NFA console and web display.
NFA console, Harvester, and DSA components on separate servers
Open the following ports in a three-tier distributed deployment to allow communication among the NFA console, Harvesters, DSAs, and other elements.
From
To
Port [Function]
NFA console
Outbound
  • TCP 25 [SMTP email reports]
  • UDP 53 [DNS]
Harvester
  • TCP 3307 [CA MySQL]
  • TCP 3308 [MySQL]
  • TCP 8066 [SOAP web service calls]
  • TCP 8080 [File web server port for collecting Harvester files]
  • UDP 161 [Watchdog service]
DSA
  • TCP 3308 [MySQL]
Harvester
Routers (SNMP interface, read-only)
  • UDP 161 [SNMP polling]
Trap destination
  • UDP 162 [traps]
DSA
NFA console
  • TCP 3308 [MySQL]
  • TCP 8080 [File Web Service, which retrieves files from the NFA console without using a file share]
Router
Harvester
  • UDP 9995 [flow]
Administrators and operators
NFA console
  • TCP/HTTP 80 [UI access and SNMP web services]
  • TCP/HTTP 8381 [Single Sign-On]
  • TCP 8681 [Report Information Base (RIB) reporting]
CA Performance Center Console
NFA console
  • TCP/HTTP 80 [device and interface synchronization with CA Performance Center]
  • TCP 8681 [data import for CA Network Flow Analysis views in CA Performance Center]
Administrators
Each server
  • TCP 3389 [Remote Desktop, if Remote Desktop is used]
  • TCP 5800, 5801, 5900, 5901 [VNC, if VNC is used]
