Ports to Open for a Standalone System
Open the following ports on a standalone system to allow CA Network Flow Analysis communications to function properly.
From
To
Port [Function]
NFA console
Outbound
  • TCP 25 [SMTP email reports]
  • UDP 53 [DNS]
Harvester
Routers (SNMP interface, read-only)
  • UDP 161 [SNMP polling]
Trap destination
  • UDP 162 [traps]
Router
Harvester
  • UDP 9995 [flow]
Administrators and operators
NFA console
  • TCP/HTTP 80 [UI access and SNMP web services]
  • TCP/HTTP 8381 [Single Sign-On]
  • TCP 8681 [Report Information Base (RIB) reporting]
CA Performance Center Console
NFA console
  • TCP/HTTP 80 [device and interface synchronization with CA Performance Center]
  • TCP 8681 [data import for CA Network Flow Analysis views in CA Performance Center]
Administrators
Each server
  • TCP 3389 [Remote Desktop, if Remote Desktop is used]
  • TCP 5800, 5801, 5900, 5901 [VNC, if VNC is used]
