For a distributed deployment, CA Network Flow Analysis supports running the Harvester on dedicated Linux servers that meet the following system requirements:
If the installation server does not have JRE version 1.6 installed, the installation or upgrade program fails to launch. We recommend that you install JRE 1.6u41, the version that was used in CA Network Flow Analysis 9.1.3 testing. Untested JRE versions may produce unexpected results.
Appropriate language packs installed on all servers for localized deployments
We recommend that Linux Harvester servers meet the following specifications:
If you do not have enough available space in the /tmp directory and you cannot configure it, relocate the directory. Export the IATEMPDIR environment variable (for the Install Anywhere temporary directory) to set a new location, and select a directory with sufficient space.
Notes:
| Copyright © 2013 CA. All rights reserved. |
