Administrators and designers can create custom menus for the Dashboards tab. Custom menus let you determine the dashboards available to each user account. Ideally, at login, CA Performance Center operators see three or four menus on the Dashboards tab that contain only the data that they require.
If your user account has the necessary role right, you can also create custom dashboards to populate a custom menu.
Custom dashboards that are included in a user’s My Dashboards menu are not visible to other users. Users can therefore copy a dashboard from a factory menu to their My Dashboards menu and then customize it.
A custom menu is not available to any users until the administrator edits a role to include it. The role must, in turn, be assigned to a user account.
| Copyright © 2013 CA. All rights reserved. |
