You can enable SNMP traps to be sent to a third-party network monitoring program. If you enable SNMP trap alerts, an SNMP trap is sent each time a threshold violation triggers an alert. You also can set the alert to be triggered only by a correlated anomaly.
Multiple targets for SNMP traps are not supported.
Use the MIB file to import the CA Anomaly Detector Object IDs (OIDs) into your trap receiver. The MIB file is located in the following directory on the CA Anomaly Detector server:
<install_path>\NQAD\MIB\AnomalyDetector.MIB
The steps for importing the OIDs and configuring the trap receiver are specific to the trap receiver.
The Data Source List page opens.
The Monitored Products page opens.
The Alert Targets page opens.
The Edit Alert Target page opens.
This is the recommended setting for first-time use of CA Anomaly Detector. If you have already disabled alerts for the sensors that are irrelevant to you, the recommended setting is Basic State. For more information about these recommendations, see the Best Practices note at the end of the topic about configuring Syslog alerts.
For information about what constitutes a correlated anomaly, see Correlated Anomalies on page 7.
You return to the Alert Targets page, which reflects any changes you saved.
| Copyright © 2013 CA. All rights reserved. |
