You can configure sensors to have different probability thresholds and to include the following optional features: absolute thresholds, alerts, and host exclusions.
The Data Source List page opens.
The Monitored Products page opens.
The Sensors page opens and displays the first group of sensors. Click the page numbers at the bottom to page through the sensor list.
The Edit Sensor page opens.
The probability threshold determines the likelihood that the sensor will send out alerts when it detects the behavior it monitors. For more information about probability thresholds, see Probability Thresholds.
Enter the absolute threshold value based on the unit of measure for the sensor. An absolute threshold signals an anomaly if the threshold is exceeded. The anomaly triggers an alert if you select the Alert option. For information about the units of measure for absolute thresholds, see Absolute Thresholds.
Absolute thresholds are applied before probability thresholds. The program continues to calculate the percentiles for the host/sensor combination even if you set an absolute threshold. These calculations are used if the absolute threshold is removed later or if the probability threshold is exceeded first. An anomaly is created if either threshold is exceeded.
This option is enabled for most sensors by default. The exceptions are sensors that are most useful when you monitor correlated anomalies (that is, when alerts are triggered for multiple types of sensors).
For information about settling up Syslog or SNMP trap alert targets, see Configure Alert Targets.
The IP address appears in the White List field.
You return to the Sensors page, which reflects any changes that you saved.
| Copyright © 2013 CA. All rights reserved. |
