When you click the Flow Forensics tab, the Saved Report Folders pane is displayed on the left and the existing reports are displayed on the right.
You can perform the following tasks in the Saved Report Folders pane: create folders, rename folders, and delete custom folders. You cannot delete the default Flow Forensics Reports folder, which is built in to CA Network Flow Analysis. Create additional folders to provide more extended organization for your Flow Forensics reports.
The right pane displays the Flow Forensics report definitions in the currently selected folder. Use the links at the top and bottom of the pane to delete or run selected reports, as well as to create or move reports.
