You can export a view and share it with coworkers who do not have access to dashboards. CA Performance Center can generate a special uniform resource locator (URL) to recreate a selected data view on demand. The URL lets you add the view to a web page or intranet site to share performance data with coworkers. The Generate URL feature lets you involve others in capacity-planning and infrastructure upgrade decisions and lets you share status information.
The Generate URL dialog opens. The URL is displayed in the URL field.
Displays the chart or graph with a surrounding container. The container includes the title of the view in a title bar and a black outline around the chart or graph.
Default: Enabled
Enables users to drill down from the view into the underlying data source for more detailed data. These users must have a minimal product privilege to the data source and the 'Drill into Data Sources' role right to use this feature.
Default: Enabled.
Let you change the time frame for the data in the exported view. Supply a custom time frame in the Start Time and End Time fields, or select a Time Range from the drop-down list.
Control view expiration. The default, 'Never' expires, lets the exported view display indefinitely.
If you want the view to expire, select a timeout period from the Token Expiration drop-down list. The URL includes an encrypted token that causes the view to expire after the specified timeout period.
