Previous Topic: Top Protocols (Bar)
Next Topic: Top Protocols (Table)
Top Protocols (Pie)
The Top Protocols (Pie) views show the protocols that are associated with the highest volumes of network traffic on the selected interface. You can use this information for quick comparisons of the amounts of inbound and outbound data for particular applications on the interface, for example.
The Top Protocols (Pie) view shows the amount and percentage of traffic for each protocol.
The view includes a pie chart and table of information about the high-volume protocols on the selected interface. A text string near the top of the view identifies the interface whose data is displayed. The table includes the following information by default:
Protocol Name
Identifies the protocol by its keyword and TCP/UDP port assignment.
Total
Records the total amount of network traffic on the interface that is associated with the protocol (for example, in number of megabytes).
Percent
Records the percentage of the total network traffic for the displayed protocols that is associated with the particular protocol.
By default, views and reports show the most recent 24 hours of data.
To see a Top Protocols (Pie) view in CA Performance Center, add it to a custom dashboard.
Available Actions for This View
You can perform several actions in this view, including the ones in the following list:
Find Protocol Pie Charts in the NFA Console
You can display pie charts with protocol traffic volumes in the NFA console for any interface that you have selected:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
