Previous Topic: Work with Harvesters
Next Topic: Edit Harvester Details
Add and Delete Harvesters
Add and delete Harvesters on the Harvester page.
To add a Harvester, complete the steps in the topic Add a Harvester.
To delete a Harvester, complete the steps in this topic.
Note: If you delete a Harvester in CA Network Flow Analysis 9.1.1, you cannot add the same Harvester instance again successfully unless the installation server has been re-imaged and the Harvester software has been re-installed. Once you delete a Harvester, you cannot recover any of the data that the Harvester collected previously.
  1. Open the Harvester page:
    1. Select Administration from the NFA console menu.
    2. Select System: Harvester from the Administration page menu.
      The Harvester page opens and displays a table of information about the current Harvesters.
  2. Click Delete in the row for the Harvester that you want to delete.
    A confirmation message opens.
  3. Click Yes to confirm that you want to delete the Harvester.
    The Harvester is deleted and is not listed in the Harvester table. The NFA console no longer collects data from the routers that are associated with the deleted Harvester. The data that was collected from those routers previously is not available in reports.
