Previous Topic: Specify Schedules for Auto-Generated Reports
Next Topic: Manage Custom Reports
View Custom Reports
When you have defined the Custom Reports that you need, you are ready to generate a new report and view it in the NFA console. You can run and view the following types of reports:
  1. Select Custom Reporting from the NFA console menu if the Custom Reporting page is not already open.
    The Custom Reporting page contains two panes. The left pane lists the folders that store saved reports. The right pane lists the reports in the currently selected folder.
  2. Click the name of the folder that contains the report you want to view.
  3. Click the report name in the Reports list.
    The report runs. The results are displayed when report generation is complete.
  4. (Optional) Change the type of presentation by selecting an option from the Report Type list.
    The default presentation type is Custom layout. The other available options are dependent on the filters that are defined for your report.
    When you select an option other than Custom Layout, a Presentation menu is added on the left side of the page. You can select from the presentation types and from the data types to modify your view. For example, you could change from a pie chart to a stacked trend chart that shows volume.
Also See:
Set the Presentation Options
