Previous Topic: Custom Reports
Next Topic: Set Up Custom Reports
Report Types and Usage
Custom Reports can show a variety of data, including the following types of information:
Report on Network Utilization
Create a custom interface report to select the included interfaces so that you can report on network traffic by:
Report on Application Distribution
Create a custom protocol report to focus on the applications and protocols in use in your organization. You can generate protocol distribution reports to:
Report on ToS Distribution
Create a custom ToS report to identify the ToS categories for the most heavily utilized applications in your environment. You can generate ToS reports to:
Report on Server Activity
Create a custom host report to identify the amount of traffic sent to and from particular servers in your organization. You can generate host reports to:
