Previous Topic: Configure the Display of Interface Utilization Data
Next Topic: Review Interface Use
Top Interfaces
The middle view on the Enterprise Overview page displays the interfaces in your network that are most heavily used for inbound and outbound traffic during the reporting period.
Each bar is identified on the left by its parent router and interface name. By default, a red bar indicates that the interface exceeds a utilization threshold of 75 percent. An orange bar indicates that the interface utilization is less than 75 percent, but has a utilization of at least 50 percent. A green bar indicates that the interface utilization is less than 50 percent.
Note: The Top Interfaces views are similar to the Routers with the Most Flow Traffic view on the Infrastructure Overview dashboard in CA Performance Center. The Most Flow Traffic view in CA Performance Center shows the total traffic rather than only the inbound or outbound traffic for each interface, however.
You can perform the following tasks in the Top Interfaces views:
More information:
Display Additional Information
