Previous Topic: Flow Forensics Reports
Next Topic: Work with Flow Forensics Reports
Flow Forensics Report Types
The following topics describe the available Flow Forensics reports.
Address Report Group
Address Pairs Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of each source and destination address pair.
Destination Address Peer Count Report
Displays the following information about each traffic destination:
Destination Addresses Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of each traffic destination.
Source Address Peer Count Report
Displays the following information about each traffic source:
Source Address Peer Count with Destination Port Report
Source Addresses Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of each source address.
ICMP Report Group
Bad IP Headers Report
Displays the source address and flow count of each bad IP header--each IP header that failed the checksum.
Fragmentation Required and DF Flag Set Report
Displays the following information about packets that require fragmentation--packets that had unreachable hosts or that were flagged Fragmentation Needed and Don't Fragment:
ICMP Traffic Summary Report
Summarizes the Internet Control Message Protocol (ICMP) types and codes that occurred. The report contains the following information:
Ping Conversation Pairs Report
Displays the following information about ping requests:
Ping Destinations Report
Displays the following information about ping request destinations:
Ping Sources Report
Displays the following information about ping request sources:
Traceroute Requests by Destination Report
Displays the following information about traceroute request destinations:
Traceroute Requests by Source Report
Displays the following information about traceroute request sources:
Traceroute Requests Pairs Report
Displays the following information about each traceroute address pair:
TTL Expired in Transit Report
Displays the following information about data that met or exceeded the Time To Live (TTL) threshold:
Unreachable Destination by Source Report
Displays the following information about sources that tried to connect with unreachable destinations:
Unreachable Destination Networks Report
Displays the following information about unreachable destinations:
Unreachable Destinations Report
Displays the following information about sources and unreachable destinations:
MAC Report Group
Destination MAC Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count on each destination Media Access Control (MAC) address.
MAC Pairs Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count on each pair of source and destination MAC addresses.
Source MAC Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count on each source MAC address.
MPLS Reports
MPLS Labels Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of traffic that had a unique combination of the following values:
Network Reports Group
Autonomous System Pairs Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic between a pair of source and destination autonomous systems.
Autonomous System Pairs (with Destination Network) Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic that had a unique combination of the following values:
Destination Autonomous Systems Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic on each destination autonomous system.
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of traffic on each destination network and subnet.
Network Pairs Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic on each pair of source and destination network subnets.
Network Pairs (with ToS) Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic on each network pair that had a unique combination of the following values:
Next Hops Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic for each next-hop address.
Source Autonomous Systems Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic on each source autonomous system.
Source Networks Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic on each source network and subnet.
TCP Resets Report
Displays the TCP reset count of traffic on each source and destination address pair.
QOS Report Group
Differentiated Services Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the traffic flow count for each DiffServ code point (DSCP) value.
Types of Service Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the traffic flow count for each Type of Service (ToS).
Session Report Group
Client-Server Sessions
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each session that had a unique combination of the following values:
Conversation Sessions Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count and cumulative flow duration of each conversation session that had a unique combination of the following values:
Conversations Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic for each IPv4 address pair that had a unique combination of the following values:
Conversations (IPv6) Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic for each IPv6 address pair that had a unique combination of the following values:
Conversations (with Interfaces)
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each conversation that had a unique combination of the following values:
Destination Applications Report
Destination Endpoints Report
Protocols Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of traffic that had a unique IP protocol.
Server-Client Sessions Report
Displays the volume, rate, and percent of total inbound bytes and packets. Also displays the flow count of each traffic session that had a unique combination of the following values:
Source Applications Report
Source Endpoints Report
TCP Reports
TCP Flags Report
Displays volume, rate, and percent of total inbound bytes/packets, as well as the flow count of traffic for each TCP flag.
VLAN Report Group
Destination VLANs Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of traffic on each destination VLAN.
Source VLANs Report
Displays the volume, rate, and percent of total inbound bytes/packets, as well as the flow count of traffic on each source VLAN.
VLAN Pairs Report
Displays the volume, rate, and percent of total bytes in/packets in, as well as the flow count of traffic on each source and destination VLAN pair.
