When you log in to the NFA console, the Interfaces page is displayed by default. This page includes the Interface Index, which you can use to select an interface and view reports for that particular interface. You can also search for a router or a group in the Interface Index.
Note: The Group tab appears in the Interface Index view provided CA Network Flow Analysis is registered as a data source with CA Performance Center. If CA Network Flow Analysis is not registered, the Interface tab appears in place of the Group tab.
To change the number of items that are shown on each page, use the Max per Page option in the top right corner.
