Previous Topic: Delete Application Mapping Rules
Next Topic: Create Reserved Seating Rules
Work with Reserved Seating
You can create Reserved Seating rules to help ensure that reports include the port and protocol combinations that interest you, regardless of traffic volume or rates. The rules create ‘reserved seats’ for the ports that are used by those protocols so the data is sure to be included in reports.
For example, during an application rollout you may want to watch the traffic for the application. The Top N Protocols reports for interfaces do not show traffic for the application. The protocol that the application uses is not included in the Top N Protocol group--the group of protocols with the highest traffic volume or utilization rate. You create a Reserved Seating rule to collect data for the specific protocol and port that the application uses. The protocol now shows up in the Top N Protocols reports.
Note: The data that CA Network Flow Analysis typically collects is described in the topic How Data Is Collected.
More information:
Edit Reserved Seating Rules
Delete Reserved Seating Rules
