Previous Topic: Configure CA Network Flow Analysis Traps for Use in External Tools
Next Topic: Expire Stale Addresses
Troubleshoot Issues with Integrated Traps
Review trap settings to correct problems with CA Network Flow Analysis trap data that is received by external fault management tools.
  1. Verify that the trap destination is set to the IP address of the server that is used to install the fault management tool.
  2. Verify that the traps are configured properly. For more information, see Create Traps.
If you have checked these settings and you still do not receive traps as expected, contact CA Support for help.
