Customizing CA Network Flow Analysis › Work with Interface Groups and Aggregations › Edit Multiple Interface Aggregations
Edit multiple interface aggregations to change the interface speed or interface type quickly.
- Display the Aggregation Interfaces page:
- Select Administration from the NFA console menu.
- Select Interfaces: Aggregations from the Administration page menu.
The Aggregation Interfaces page opens and shows the current list of interface aggregations.
- Click the check boxes next to the aggregations that you want to edit. To select all aggregations, click the check box in the heading row.
- Click Edit.
The Edit Interfaces dialog opens.
- Change the following settings as needed:
- In Speed: (Optional) Inbound speed of the selected interfaces
- Out Speed: (Optional) Outbound speed of the selected interfaces
- Type: (Optional) Mode of interface connection, such as WAN or Ethernet
- Click Save.
Your changes are saved and you return to the list of aggregations.
