You can start or stop CA Network Flow Analysis services or check the status of a service in the Windows Services window.
The CA Network Flow Analysis services are described briefly in the following list. If the CA Network Flow Analysis components are installed on more than one server, the services run on each server as shown in the following list. If all the components are installed on a standalone system, all the services run on the standalone server.
The following lists identify the CA Network Flow Analysis service names as they appear in the Services window on Windows servers. The table also lists the services associated log file names and locations, along with any available configuration file to control the log level setting.
Log name and location: <NFA_install_path>\Reporter\RIB\NFA\webapps\NFARS\WEB-INF\logs\application.log
Log name and location: <NFA_install_path>\ProxyServices\Logs\DnsProxyWSLog<yyyy-mm-dd>.log
Log level setting: <NFA_install_path>\ProxyServices\Web.config
<add key="LogLevel" value="6"/> Default: 4
Manager Service log name and location: <NFA_install_path>\Reporter\Logs\Manager Service Log<yyyy-mm-dd>.log
Log level setting: <NFA_install_path>\Reporter\bin\ ReporterManagerService.exe.config
<setProperties Severity="6" /> Default: 4
Log name and location: <NFA_install_path>\Reporter\Logs\nqservErrors<yyyy-mm-dd>.log
Log name and location: <NFA_install_path>\Reporter\Logs\PumpLog<yyyy-mm-dd>.log
Log level setting: <NFA_install_path>\Reporter\NetQoS.ReporterAnalyzer.PumpService\bin\NetQoS.ReporterAnalyzer.PumpService.exe.config
<setProperties Severity="6"/> Default value: 4
Log name and location: <NFA_install_path>\Reporter\Logs\ManagerService_AutomaticGroupsLog<yyyy-mm-dd>.log
Log name and location: <NFA_install_path>\Reporter\Logs\ManagerService_DnsLog<yyyy-mm-dd>.log
Log name and location: <NFA_install_path>\Reporter\Logs\ManagerService_MaintenanceLog<yyyy-mm-dd>.log
<NFA_install_path>\Reporter\Logs\WatchdogLog<yyyy-mm-dd>.log
Log level setting: <NFA_install_path>\Reporter\ NetQoS.ReporterAnalyzer.WatchdogService\bin\WatchdogService.exe.config <setProperties Severity="6"/> Default value: 4
Log name and location: <NFA_install_path>\Reporter\Logs\FlowForensicsLog<yyyy-mm-dd>.log
Log level setting: <NFA_install_path>\Reporter\NetQoS.ReporterAnalyzer.ReportService\ bin\NetQoS.ReporterAnalyzer.ReportService.exe.config
<setProperties Severity="6" /> Default value: 4
To log each poll in addition to regular event logging:
<add key="VerboseLogging" value="True"/>
Log name and location: <NFA_install_path>\Netflow\Logs\collpollws-wrapper.log
Log name and location: <NFA_install_path>\Netflow\Logs\proxies-wrapper.log
No option for log level setting.
Harvester log name and location: <NFA_install_path>\Netflow\Logs\harvester-wrapper.log
Log name and location: <NFA_install_path>\Netflow\Logs\dataretention-wrapper.log
Log name and location: <NFA_install_path>\Netflow\Logs\filewebservice-wrapper.log
Log name and location: <NFA_install_path>\Netflow\Logs\poller-wrapper.log
Reaper log name and location: <NFA_install_path>\Netflow\Logs\RealtimeReaperErrors<yyyy-mm-dd>.log
NQ MySQL log name and location: <NFA_install_path>\Netflow\Logs\oursql_5.1_error.log
Log name and location: <NFA_install_path>\MySql51\data\<server_name>.err
