If your user account has the required role right, you can export the current dashboard contents as a printed report. The Print feature first displays the current dashboard page in PDF format.
The report is exported as a PDF. Typically, it is displayed in a separate browser window.
The data uses the current dashboard settings.
The report page is sent to the local default printer.
