Previous Topic: Edit a Menu
Next Topic: Administering CA Network Flow Analysis
Delete a Menu
When a menu is no longer being used, you can delete it.
Note: Deleting a user account that is associated with a custom menu does not delete that menu.
  1. Log in as a user with the required administrative role rights.
  2. Navigate to the Manage Menus page.
    The Manage Menus page displays the current list of menus.
  3. Select the menu that you want to delete, and click Delete.
    The Delete Menu dialog opens.
  4. Click Yes to confirm the deletion.
    The menu is deleted and no longer appears on the Dashboards tab when the associated user logs in. Any dashboards that are contained in the menu definition are not affected and can be added to other menus.
