Previous Topic: Requirements for Linux Servers
Next Topic: Configure SNMP on a Linux Server
System Requirements for Linux Servers
For a distributed configuration, CA Network Flow Analysis supports installing the Harvester on Linux servers that meet the following requirements:
If you do not have enough available space in the /tmp directory and you cannot configure it, relocate the directory. Export the IATEMPDIR environment variable (for the Install Anywhere temporary directory) to set a new location, and select a directory with sufficient space.
Notes:
Important: CA Network Flow Analysis requires DNS resolution. If DNS is not configured, add system entries to the /etc/hosts file on your server manually.
