Previous Topic: Add and Delete Harvesters
Next Topic: Customizing CA Network Flow Analysis
Edit Harvester Details
Edit the details for Harvesters on the Harvester page. You can edit the IP address, description, and tenant/domain setting.
  1. Select Administration from the NFA console menu.
  2. Select System: Harvester from the Administration page menu.
    The Harvester page opens and displays a table of information about known Harvesters.
    The Harvester page includes the following options:
  3. Click Edit on the Harvester row that you want to edit.
    The Edit Harvester dialog opens.
  4. (Optional) Change any of the following settings as needed:
    IP Address
    Address of the Harvester
    Description
    (Optional) Additional information to help identify the Harvester on the Harvester page
    Domain
    Combination of the tenant and domain for the Harvester
    Default: Default Tenant\Default Domain
    Note: If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
  5. Click Save when you are finished making changes.
    Your changes are saved immediately and appear in the Harvester table.
