Previous Topic: Create Reserved Seating Rules
Next Topic: Delete Reserved Seating Rules
Edit Reserved Seating Rules
Edit a Reserved Seating rule to make corrections in the specified port, protocol, or description.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
      The Application Definitions page opens.
  2. Select Reserved Seating from the Rules list.
    The Application Definitions page switches to Reserved Seating mode and displays a list of the current Reserved Seating rules.
  3. Click the check box next to the rule you want to edit, then click Edit.
    The Edit Reserved Seating dialog opens.
  4. Make the needed changes in the Protocol, Port, and Description values, then click Save.
    If the changes are successful, the Edit Reserved Seating dialog closes.
